This teardown is not a repair guide. To repair your Framework Expansion Cards, use our service manual.
  1. Framework Expansion Cards Teardown, Unscrew the case: step 1, image 1 of 2 Framework Expansion Cards Teardown, Unscrew the case: step 1, image 2 of 2
    • Unscrew outer screws located next to the male USB-C connection. On only the Ethernet expansion card there is another set on the bottom by the Ethernet end.
  2. Framework Expansion Cards Teardown, Slide the cover off: step 2, image 1 of 3 Framework Expansion Cards Teardown, Slide the cover off: step 2, image 2 of 3 Framework Expansion Cards Teardown, Slide the cover off: step 2, image 3 of 3
    • Slide the cover towards the male USB-C connector
    • It may take some force
    • The Ethernet expansion card moves much less than the other cards
    • Then lift the cover off
    • Ethernet is also held on by clips
  3. Framework Expansion Cards Teardown, Unscrew the PCB: step 3, image 1 of 2 Framework Expansion Cards Teardown, Unscrew the PCB: step 3, image 2 of 2
    • Unscrew the 2 screws holding in the PCB (the circuit board)
not-ethan
429 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 102
Past 30 Days: 142
All Time: 142
