This teardown is not a repair guide. To repair your FitBit Alta HR, use our service manual.
    1. FitBit Alta HR Teardown, Removing screen cover: step 1, image 1 of 3 FitBit Alta HR Teardown, Removing screen cover: step 1, image 2 of 3 FitBit Alta HR Teardown, Removing screen cover: step 1, image 3 of 3
      • Make sure your band is taken off before starting this step.
      Ask FixBot
    2. FitBit Alta HR Teardown, Lifting open the screen: step 2, image 1 of 3 FitBit Alta HR Teardown, Lifting open the screen: step 2, image 2 of 3 FitBit Alta HR Teardown, Lifting open the screen: step 2, image 3 of 3
      • Be careful not to scratch the motherboard.
      Ask FixBot
    3. FitBit Alta HR Teardown, Disconnecting heart rate monitor cable: step 3, image 1 of 2 FitBit Alta HR Teardown, Disconnecting heart rate monitor cable: step 3, image 2 of 2
      • Do this gently.
      Ask FixBot
    4. FitBit Alta HR Teardown, Unscrew motherboard: step 4, image 1 of 3 FitBit Alta HR Teardown, Unscrew motherboard: step 4, image 2 of 3 FitBit Alta HR Teardown, Unscrew motherboard: step 4, image 3 of 3
      • Use the 0.7 screwdriver to unscrew this.
      Ask FixBot
    5. FitBit Alta HR Teardown, Removing Battery: step 5, image 1 of 3 FitBit Alta HR Teardown, Removing Battery: step 5, image 2 of 3 FitBit Alta HR Teardown, Removing Battery: step 5, image 3 of 3
      • Be careful not to puncture the battery you pry with metal tools.
      • Be careful with the wires connecting the battery to the motherboard.
      Ask FixBot
John Kosowicz
130 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 40
All Time: 2,959
