This teardown is not a repair guide. To repair your First alert smoke and carbon monoxide alarm, use our service manual.
  1. First alert smoke and carbon monoxide alarm Teardown, Step 1.: step 1, image 1 of 1
    • The First Alert Smoke and Carbon Monoxide Alarm. There when you need it, also there when you don't need it and the batteries are low.
  2. First alert smoke and carbon monoxide alarm Teardown, Step 2: step 2, image 1 of 1
    • You're going to want to get a flat head screwdriver and pry open the clip on the inside to get to the inner part of the alarm.
  3. First alert smoke and carbon monoxide alarm Teardown, Step 3.: step 3, image 1 of 1
    • After the last step you can now see the inside.
  4. First alert smoke and carbon monoxide alarm Teardown, Step 4.: step 4, image 1 of 2 First alert smoke and carbon monoxide alarm Teardown, Step 4.: step 4, image 2 of 2
    • Now what you should do is pop a small screwdriver into the rivet hole to unlock the battery holder.
  5. First alert smoke and carbon monoxide alarm Teardown, Final Step.: step 5, image 1 of 1
    • Now with the the battery back area being popped out you can safely take out the ringer and the mother board of the smoke detector.
    • Electricity works in a smoke detector by detecting smoke via a air filtration tank and when it detects the smoke it send a electric signal to a air horn to beep every 3-5 seconds.
Justin Lyons
150 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 55
All Time: 5,543
