Introduction
Fairphone has generated a fair amount of chatter within the repair community by making a fair-trade phone. Join us and find out if their commitment to a "smart, open design" and "lasting value" will make for the repairable phone of every fixer's dreams.
We managed to get our sneaky hands on Fairphone #3. No, seriously — the device we took apart is the third unit that came off Fairphone's prototype line! So some pieces may be a bit "rough around the edges" or have markings that don't show up in actual production units, but that’s the price we pay for having exclusive access to the phone.
Want to hear more about our own dedication to repair and device ownership? Check out iFixit.org, check us out on Facebook , or get the redux on Twitter.
With its unconventional goals, Fairphone isn't gonna be the flashiest flagship phone on the block, but it's still a solid smartphone that'll hold its own feature-wise:
4.3" Quarter-HD (qHD) (960 x 540 pixels) display with 256 ppi
MediaTek MT6589M (quad-core) 1.2 GHz processor
16 GB integrated storage expandable by microSD (up to 64 GB) + 1 GB RAM
2000 mAh user-replaceable battery
8 MP rear-facing camera with autofocus (stabilization + image sensor) + 1.3 MP front-facing camera
Wi-Fi 2.4GHz 802.11b/g/n Wi-Fi and Bluetooth v2.1 + EDR / v3.0 + HS (802.11 AMP) / v4.0 LE
The battery cover has some serious heft, no doubt for structural aid and durability.
Update: We got one of the actual shipping units post-teardown, and confirmed that the floppy battery cover attaches to the rest of the phone nice 'n' securely.
On the inside of the battery cover, we find an engraving commemorating the first supporters of Fairphone's grand vision: "This phone and you and 9635 people made fairphone possible."
Out first is the advertised user-replaceable 2000 mAh battery.
Comparatively:
The iPhone 5s sports a 1560 mAh battery, with up to 250 hours of standby.
The Samsung Galaxy S4 comes in at 2600 mAh, with up to 300 hours of standby.
Tool used on this step:iFixit Opening Picks (Set of 6)$4.99
A little gentle prying with our snappy opening pick pops the clips along the midframe.
This style of midframe reminds us of most Samsung phones on the market, and the opening procedure is about on par.
actually, i'm pretty sure you haven't actually *done* this: if you don't remove the five screws that secure the back to the midframe, no amount of prying will get the phone apart (unless you have a ifixit crowbar and decided that you'll want an iphone after all). note: on my phone, one of the screws was initially covered with a black sticker. it's next to where the outer-most SIM appears from under its cover.
(all this on a FP1)
Thank you for writing this Marten - I was struggling and almost breaking the case until I found your "hidden screw" tip. Many thanks
Jo -
WTF dude, you forgot to mention the screws! There are 4 visible and one hidden under a sticker. Plus you don't mention not to pry under the power button or the jacks. Here's a REAL guide, with FULL instructions: Fairphone 1 Display Assembly Replacement
This is just a first peek at the device, "Teardowns provide a look inside a device and should not be used as disassembly instructions." But thanks for providing users links to our replacement guides. =)
Regardless if this is a teardown or disassembly instructions, mentioning the "snappy opening pick" but not the 5 screws is simply misleading and may cause people to damage their phones.
I don't know why this isn't even worth a small note to avoid this.
Hi gmdode, This is a teardown, it's only a peak inside the device and NOT meant to be followed as disassembly instructions, we have a banner at the top to warn you! Check out one of our eleven replacement guides instead!
With minimal finagling, we free the motherboard and throw it on the table to take a looksie.
The 8 MP rear-facing camera comes out with ease, but several other components are unfortunately soldered in place:
Front-facing camera
Vibrator motor
LED flash
Headphone jack
We're hopeful that future revisions of the Fairphone will be more modular, and more cost-effective to repair.
On the flip side:
RFMD RF3236 WEDGE (Linear) Transmit Module
AzureWave AW-NH520, probably similar to the AW-NH580 802.11 b/g/n WLAN, Bluetooth, GPS and FM Combo Module IC
MediaTek MT6167A RF Transceiver
Skyworks SKY77768-1 SkyHi Power Amplifier Module for WCDMA/ HSDPA/ HSUPA/ HSPA+/ LTE – Band VIII (880–915 MHz)
Skyworks SKY77761 SkyHi Power Amplifier Module for CDMA / WCDMA / HSDPA / HSUPA / HSPA+ / LTE – Band I (1920–1980 MHz)
Fairphone repairability score: 7 out of 10 (10 is easiest to repair).
The battery can be replaced without any tools.
It's very easy to open and access the internal components.
There are only 8 screws in the entire device, all standard Phillips #000 (no proprietary or security).
The Fairphone comes with a set of free, open source repair manuals.
Several smaller components are soldered to the motherboard, increasing repair difficulty (front-facing camera, vibrator motor, LED flash, and headphone jack).
The glass is fused to both the display and the display frame, increasing repair costs.
Is it true for fairphones from the production batch, that the glass is fused to display and frame? In one blogpost [1] they put great emphasize on how they decided to have "separated the glass touch panel and the protective touch panel". I thought this meant that glass and display were easy to repair.
[1] Search for "Hardware Development Ordering" on http://www.fairphone.com/2013/06/28/prod...
@FGN That is true, and they want to change it:
"If the glass breaks, the touchpanel will still work in most cases; however, when we ship the display assembly, these two parts are glued together. This is not ideal, so we're looking into it for next generation devices."
Funny people should mention the idea of making boards more modular to upgrade the phone. I am in the early thinking it out stages of designing a phone and tablet line that is 100% user serviceable and highly rugedized.
Things the phone and tablet will not be. silly stupid overly thin. Glass and digitizer will be 1 part and lcd another. Switches charger etc will be connected more old school plastic connector to pins and they will not be blister buttons but micro switches. The cpu ram etc will be the fastest possible with the largest amount possible. I seen that some dev boards have of all things sata controllers. 1tb ssd any one?
while thicker than average by a good bit it will be worth it. As my end game plan for the phone and tablet is gaming emulation and android specific games etc. Ill post more later on as i move along
10 Comments
If the Fairphone manufacturer/producer wants to score 10/10, it should be a world phone useable on any network and be upgradeable to newer technology by just purchasing and installing replacement boards, similar to what can be done with desktop computers which can be upgraded without replacing the whole thing. It should also be able to run various operating systems including Android, Windows 8, etc. and multi-boot into the desired OS (like HTC HD2).
Setting the bar too high there. Yes that would be the absolute perfection in phone design, but we can't even do that with ultrabooks, never mind tablets or even smartphones. Baby steps. Lets get our devices fully repairable before we start upgrading them. And maybe once upgradable phones come out, ifixit will start a new upgradeability rating?
What obsoletes many smartphones (at least in the minds of typical users) is the phone OS. What are the plans to have an OS software upgrade process that does not require the average user to have to root the phone and go through the esoteric process that exists today?
The updater for the Fairphone was kind of ok, just there were no updates. They never moved beyond Android 4.2.2, and now many apps don’t run on the FP1 anymore. I guess a factor was that they chose a mediatek board, and Mediatek is one of the least open source friendly companies out there, so that they could not port the drivers to newer android versions.
Do anyone know the specifications or part number for the 3.5 mm phone jack (headset)?
I have contacted fairphone several times about this issue, but they are either unable to understand my english or are just avoiding to answer the question... :)
No phones I've ever heard of except old feature phones and all of the apple smartphones that are older than the 4 have non-fused glass.
Fused glass makes sense, I've had to replace the LCD on an old iPhone, getting all the dust out is unbelievably frustrating and takes a long time.
Also, if you drop your phone in water, the sealed screen will almost always work, but with the non sealed, Water gets in between the screen and the capacitive overlay, which won't dry (or will take forever to do so) which means that you'll have to separate the two halves of the screen and clean them.
Overall I personally like glued screens, because they simplify repair.
With the side affect of being more expensive in mind, I usually shop on eBay/Amazon for screens
-Alec
What are the specifications of the micro-USB-socket? (type, sizes, ...) ?
I would like to buy one _before_ the start of the teardown.
I don’t know but the micro sd port is soldered onto the motherboard, so replacing it is quite a challenge. In Berlin I found a service store who replaced my broken socket, but after just a month it broke again. My impression is that this has hit literrally thousands of FP1 users. Truly bad design there.
Burt my is a zote n817
Its azten 817
