Fix Your Stuff
Right to Repair
Parts & Tools
Tools Featured in this Teardown
This teardown is not a repair guide. To repair your Expansion Plus, use our service manual.
  1. Using a flat head screwdriver or plastic tool
    • Using a flat head screwdriver or plastic tool
  2. Remove the cover
    • Remove the cover
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Remove the drive from the case
    • Remove the drive from the case
  5. Peel back the shielding
    • Peel back the shielding
  6. Remove the Screw with the #02 screw driver
    • Remove the Screw with the #02 screw driver
  7. Separate the adapter form the sata port Separate the adapter form the sata port
    • Separate the adapter form the sata port
Dan
2,211 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 114
All Time: 229
