Introduction
Teardown of an Epson Stylus Photo 820 Inkjet Printer.
This is a teardown of the Epson Stylus 820 Photo color printer.
The inside of the power supply.
The metal strip contains many spiked wheels rotating on springs which allow them to be pushed out of the feed path.
the spiked wheels seems to be called starwheels, but not sure what they are used for...
This inky mess is the nozzle cleaner.
The assembly is spring loaded so the nozzles can be pushed into a pad to collect ink, which is then somehow transferred into the large absorbent ink pad.
there should be a waste ink pump and waste ink tube somewhere. The springed structure is for capping the print nozzle to slow down their drying out only, not to suck the ink.
To remove the metal midframe of the printer, three screws must be removed.
The gearbox is going to be the next thing to be removed...
and the thing where the tube passed through is the pump. That is whats sucking out the ink. It seems to be driven by the main shaft also.
there might be service manual available for those printers online somewhere, and technical details can sometimes be found.
The main stepper motor, the part most likely to fail, is easy to remove.
The ink cartridges are easily replaceable.
Many parts inside the printer have ink on them, making repairs messy.
The other stepper motor is very hard to access and requires disassembling most of the printer.
The midframe, which contains the gearbox and secondary stepper motor, is attached to the case with blobs of melted plastic that must be cut off to remove.
The case is very hard and tedious to open without breaking tabs.
Bonus Teardown Time!
Time to see what is underneath the 'Do not remove' sticker located on the ink cartridge.
What is this network of labyrinthine passageways?
The answer is a capillary tunnel to reduce ink pressure. The lower row of holes leads into the cartridge itself, while the top row leads to the ink nozzles.
3 Comments
Thanks for sharing this blog with us.
Epson Stylus Photo R280 Ultra Hi-Definition Photo Printer is the fast, easy way to print brilliant, 4 x 6" photos or text documents.
Wavex is a US-based Coin that specializes in crypto-enabled financial services.
