This teardown is in progress – Reload periodically to see the latest changes!
  1. Englewood Black & Decker Black Toaster OvenTeardown, Fully Assembled Toaster: step 1, image 1 of 2 Englewood Black & Decker Black Toaster OvenTeardown, Fully Assembled Toaster: step 1, image 2 of 2
    • Original, un-tampered with toaster oven. Cleaning before teardown optional.
    • BE SURE THE TOASTER OVEN IS UNPLUGGED BEFORE BEGINNING TEAR DOWN
  2. Englewood Black & Decker Black Toaster OvenTeardown, Removing the Oven's Plastic Legs: step 2, image 1 of 2 Englewood Black & Decker Black Toaster OvenTeardown, Removing the Oven's Plastic Legs: step 2, image 2 of 2
    • First you need to remove the grey, plastic caps on the legs of the toaster oven to gain access to the screws.
    • Use a phillips head screwdriver that is as narrow as possible. This makes it easier on you to get the head of the screwdriver to the actual screw, without being stopped by the oven's plastic legs.
  3. Englewood Black & Decker Black Toaster OvenTeardown, Removing Timer Knobs off the Front Pannel: step 3, image 1 of 3 Englewood Black & Decker Black Toaster OvenTeardown, Removing Timer Knobs off the Front Pannel: step 3, image 2 of 3 Englewood Black & Decker Black Toaster OvenTeardown, Removing Timer Knobs off the Front Pannel: step 3, image 3 of 3
    • Pull the knobs off with your hands. A flathead screwdriver may be used for additional leverage when removing these.
  4. Englewood Black & Decker Black Toaster OvenTeardown, Removing the Back Panel: step 4, image 1 of 2 Englewood Black & Decker Black Toaster OvenTeardown, Removing the Back Panel: step 4, image 2 of 2
    • Flip the toaster oven onto its side and use a phillips head screwdriver to remove the screws securing the back panel of the toaster to the toaster's main body.
    • DO NOT LOSE THE SCREWS
    • With the back panel no longer secured, remove it from the body of the toaster oven.
  5. Englewood Black & Decker Black Toaster OvenTeardown, Removing the Main Body of the Toaster Oven: step 5, image 1 of 3 Englewood Black & Decker Black Toaster OvenTeardown, Removing the Main Body of the Toaster Oven: step 5, image 2 of 3 Englewood Black & Decker Black Toaster OvenTeardown, Removing the Main Body of the Toaster Oven: step 5, image 3 of 3
    • The screws on the main body housing are the same type as those used for securing the back panel. There is no need to keep them separated.
    • Use a pair of pliers to remove the two screws that are neither phillips nor flat type of screw.
    • With all screws removed, the black main body of the toaster oven can be removed from the chassis.
  6. Englewood Black & Decker Black Toaster OvenTeardown, Removing the Timer, Heat Control, and Mode Control: step 6, image 1 of 2 Englewood Black & Decker Black Toaster OvenTeardown, Removing the Timer, Heat Control, and Mode Control: step 6, image 2 of 2
    • Unscrew the timer, heat control, and mode control with a phillips head screw driver.
  7. Englewood Black & Decker Black Toaster OvenTeardown, Disconnecting Wires and Modules: step 7, image 1 of 3 Englewood Black & Decker Black Toaster OvenTeardown, Disconnecting Wires and Modules: step 7, image 2 of 3 Englewood Black & Decker Black Toaster OvenTeardown, Disconnecting Wires and Modules: step 7, image 3 of 3
    • Carefully remove each of the heater's modules from the chassis.
    • Unclip the wires connecting the modules.
Aviv Weinstein
21 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 772
