This teardown is not a repair guide. To repair your EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon), use our service manual.
  1. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown, EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 1, image 1 of 2 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown, EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 1, image 2 of 2
    • Gently lift the cover off the humidifier
  2. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 2, image 1 of 1
    • Grip the dial and pull away from the device.
  3. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 3, image 1 of 2 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 3, image 2 of 2
    • Gently pull the water tank off the base
  4. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 4, image 1 of 2 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 4, image 2 of 2
    • Locate the valve at the bottom of the tank.
    • Twist the valve counterclockwise to remove it.
  5. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 5, image 1 of 3 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 5, image 2 of 3 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 5, image 3 of 3
    • Flip the base upside-down
    • Connect the 4 mm nut driver to the 4 mm aluminum driver. Then, connect the PH1 head to the 4 mm nut driver.
    • Insert the driver into each of the 4 holes and twist counter clockwise to remove the screws.
    • Flip the base upright and pull off the top.
  6. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 6, image 1 of 2 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 6, image 2 of 2
    • Connect a PH1 head to the 4 mm aluminum driver
    • Unscrew the circled screws of both the circuit board and heating plate(metal plate)
    • Gently remove the circuit board
  7. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 7, image 1 of 3 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 7, image 2 of 3 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 7, image 3 of 3
    • Gently pull out the fan (located in the red rectangle)
    • We recommend removing the circuit board before attempting to completely remove the fan.
    • Unplug the pin, connected to the circuit board, to remove the fan.
    • Note: Remove the pin cautiously, the edges may hurt your fingers.
  8. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 8, image 1 of 2 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 8, image 2 of 2
    • The LED is connected to a pin that is connected to the circuit board.
    • Upon close inspection, you can see that the LED's two ends are bent (red circle of the second image) to prevent it from slipping off of the pin.
    • Use blunt tweezers to bend and straighten the two ends.
    • Once the two ends are straight, gently pull the LED out of the pin.
  9. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 9, image 1 of 2 EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 9, image 2 of 2
    • Remove the screws (located in the red circles) off of the heating plate with a 4 mm aluminum driver with a PH1 head.
    • Once the screws are removed, gently pull off the metal plate.
  10. EMSON ​Star Wars R2-D2 Ultrasonic Cool Mist Humidifier (One Gallon) Teardown: step 10, image 1 of 1
    • All the inner components of the humidifier.
Paul
127 Reputation
1 Guide authored
USF Tampa, Team 8-5, Eyestone Spring 2017 Member of USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
4 Members
5 Guides authored
One Comment
thank you this is helpful
tostypinapple - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,145
