This teardown is not a repair guide. To repair your Doro 1881, use our service manual.
  1. Doro 1881 Teardown, Remove the back cover: step 1, image 1 of 3 Doro 1881 Teardown, Remove the back cover: step 1, image 2 of 3 Doro 1881 Teardown, Remove the back cover: step 1, image 3 of 3
    • Theres a notch at the bottom left side of the device
    • You can simply pull up on the back cover with your fingernail
  2. Doro 1881 Teardown, Remove the battery: step 2, image 1 of 3 Doro 1881 Teardown, Remove the battery: step 2, image 2 of 3 Doro 1881 Teardown, Remove the battery: step 2, image 3 of 3
    • Theres a notch just above the battery, where you can pull the battery out
  3. Doro 1881 Teardown, Unscrew the cover: step 3, image 1 of 1
    • There are 6 phillips screws around the cover (circled in the image)
  4. Doro 1881 Teardown, Remove the cover: step 4, image 1 of 3 Doro 1881 Teardown, Remove the cover: step 4, image 2 of 3 Doro 1881 Teardown, Remove the cover: step 4, image 3 of 3
    • After removing the screws, insert an opening pick from the right side of the device
    • Drag the tool upwards
    • Once you reach the edge of the cover, pull the tool towards you
    • You should hear a click, and should be able to pull the cover off
  5. Doro 1881 Teardown, Remove the board: step 5, image 1 of 3 Doro 1881 Teardown, Remove the board: step 5, image 2 of 3 Doro 1881 Teardown, Remove the board: step 5, image 3 of 3
    • You can simply pull the PCB towards you
Onni Nevala
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 52
Past 30 Days: 177
All Time: 234
