Remove the marked Phillips screws - PH0 or PH1. Due to the hole depth and diameter, you cannot reach the screw head with the iFixit bit sets. A screwdriver with a longer shaft length is required, see middle image.
The cover can be opened by gently pulling on the antenna, see first picture.
The ribbon connectors can be removed by gently levering them downwards.
Removing the battery holder - PH0 or PH1 - and the ribbon connector
Removing the PH0 or PH1 attachment part
Remove the PH0 or PH1 screws on the main board
Removing the red ribbon cable plug
Removing the antenna connection or careful handling
Rechargeable battery: 5000 mAh 7.4 V 37 Wh
Mainboard
Radio receiver board and DAB/UKW telescopic antenna
Main switch
Circuit board and 2-line 2.8 inch LCD display
Loudspeaker: 6 Ohm 5 W
Special thanks to these translators:
100%
Justus Klingler is helping us fix the world! Want to contribute?
Start translating ›
