This teardown is not a repair guide. To repair your Dell Power Supply (MH596), use our service manual.
  1. Dell Power Supply (MH596) Teardown, Dell Power Supply (MH596) Teardown: step 1, image 1 of 3 Dell Power Supply (MH596) Teardown, Dell Power Supply (MH596) Teardown: step 1, image 2 of 3 Dell Power Supply (MH596) Teardown, Dell Power Supply (MH596) Teardown: step 1, image 3 of 3
    • Remove the outside case screws as seen in all 3 photos with a medium sized screwdriver checking for NO wiggle room
    • Unplug and leave unplugged for 1-5 minutes to ensure discharge and safety when disassembling(though you don't really need to let it sit)
  2. Dell Power Supply (MH596) Teardown: step 2, image 1 of 2 Dell Power Supply (MH596) Teardown: step 2, image 2 of 2
    • Here you can now remove the top of the power supply case
  3. Dell Power Supply (MH596) Teardown: step 3, image 1 of 2 Dell Power Supply (MH596) Teardown: step 3, image 2 of 2
    • The port on the first picture is actually the power port of your computer
    • the power supply uses connections going into the computer to redirect and resist the electricity to allow the computer to perform it's tasks
  4. Dell Power Supply (MH596) Teardown: step 4, image 1 of 2 Dell Power Supply (MH596) Teardown: step 4, image 2 of 2
    • To remove the fan ween it forward and pull up with the frame facing towards you like a staircase
  5. Dell Power Supply (MH596) Teardown: step 5, image 1 of 2 Dell Power Supply (MH596) Teardown: step 5, image 2 of 2
    • To free the cables up remove all tape and zip-ties to further removal
    • This will not help your situation if you are trying to fix the power supply
  6. Dell Power Supply (MH596) Teardown: step 6, image 1 of 2 Dell Power Supply (MH596) Teardown: step 6, image 2 of 2
    • Remove a screw on the back end(with the stair pattern facing towards you) to free the back panel(partially)
  7. Dell Power Supply (MH596) Teardown: step 7, image 1 of 3 Dell Power Supply (MH596) Teardown: step 7, image 2 of 3 Dell Power Supply (MH596) Teardown: step 7, image 3 of 3
    • Remove all four screw surrounding the circuit board in charge of dispersing and changing the power
    • The top right screw is really annoying, ensure you have clipped all zip-ties and the proceed to drive yourself insane
  8. Dell Power Supply (MH596) Teardown: step 8, image 1 of 2 Dell Power Supply (MH596) Teardown: step 8, image 2 of 2
    • Gently move the board on a yaw axis(horizontal)
    • Place it on a buffer that will stop you board from scratching whatever it's on top of
  9. Dell Power Supply (MH596) Teardown: step 9, image 1 of 2 Dell Power Supply (MH596) Teardown: step 9, image 2 of 2
    • Remove glue surrounding the port that would be visible outside your computer(it is hot glue so it should be easy)
    • There are clips to pull the metal back and the black plastic through to help remove the black plastic, though I do not cover this it should never be necessary
  10. Dell Power Supply (MH596) Teardown: step 10, image 1 of 2 Dell Power Supply (MH596) Teardown: step 10, image 2 of 2
    • To remove the heat sink simply detach the two back screws with a medium sized screwdriver
    • Heat sinks are used to disperse heat, as they have a large surface area to pawn the heat off to the air around it
  11. Dell Power Supply (MH596) Teardown: step 11, image 1 of 2 Dell Power Supply (MH596) Teardown: step 11, image 2 of 2
    • These two screws can be removed using a small socket wrench
    • The bolt can be removed by something as simple as pliers(2nd picture)
  12. Dell Power Supply (MH596) Teardown: step 12, image 1 of 1
    • After all this work of disassembling this as far as you could go you surely have seen the magnificence of how crucial proper power is to a computer and everything around us, from you to what your reading on right now, we all have one thing in common: we need energy
Owen Preece
643 Reputation
3 Guides authored
One Comment
I can give you very good guidance on fixing these.
They all suffer from a VERY common problem.
Mal - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,519
