This teardown is not a repair guide. To repair your Dell Latitude D500, use our service manual.
  1. Dell Latitude D500 Teardown, Remove the screws from the bottom: step 1, image 1 of 1
    • Start by taking out the screws on the bottom. Mine already has them mostly removed, but yours most likely won’t.
  2. Dell Latitude D500 Teardown, Remove keyboard: step 2, image 1 of 3 Dell Latitude D500 Teardown, Remove keyboard: step 2, image 2 of 3 Dell Latitude D500 Teardown, Remove keyboard: step 2, image 3 of 3
    • Next, you are going to remove the panel with the power button. For this, I recommend a flathead screwdriver. After that cover is off, remove all of the screws. Once the screws are gone, pull the keyboard out. There is a ribbon cable connecting it to the board, but it has an easy to remove pull bar on it.
  3. Dell Latitude D500 Teardown, Remove the screen: step 3, image 1 of 1
    • To remove the screen, just pull the connector out of the board. There is a screw holding it in place, but it is easy to remove. The screw is shown in the photo.
  4. Dell Latitude D500 Teardown, Remove the upper casing and mouse.: step 4, image 1 of 3 Dell Latitude D500 Teardown, Remove the upper casing and mouse.: step 4, image 2 of 3 Dell Latitude D500 Teardown, Remove the upper casing and mouse.: step 4, image 3 of 3
    • To remove the upper casing, you will need to remove the connector for the trackpad. It is shown in photo two being removed. Be careful, the casing is slightly fragile. Mine has yet to break, but it could.
    • This step is a break from removing screws. All of the parts have a button to remove them.
  5. Dell Latitude D500 Teardown, Remove the power button: step 6, image 1 of 1
    • Remove the screws holding it in place, the pull the black tab
    • There are instructions on the heat sink and chip cooler.
  6. Dell Latitude D500 Teardown, Remove speaker: step 8, image 1 of 2 Dell Latitude D500 Teardown, Remove speaker: step 8, image 2 of 2
    • Remove the screws holding the speaker in place. You have to remove the bios battery, but I don’t have one. If someone could make a tutorial for that, that would be nice.
  7. Dell Latitude D500 Teardown, Remove the cd drive cover: step 9, image 1 of 2 Dell Latitude D500 Teardown, Remove the cd drive cover: step 9, image 2 of 2
    • Remove the screws holding it in place and pull it off.
  8. Dell Latitude D500 Teardown, Done: step 10, image 1 of 1
    • When complete, it should look something like this. To reassemble, follow steps in reverse.
Ethan Bullen
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 43
Past 30 Days: 67
All Time: 67
