Introduction
This teardown will show the process of taking a continuity tester apart. A continuity tester is a small electronic device that can be used to test a circuit for its open or closed state. The device operates by connecting the positive and negative leads to a circuit and pressing the small black button. If the red light illuminates, the circuit is closed. If it does not, the circuit is open.
This device was fabricated in a Cal Poly Manufacturing Engineering course. All of the resistors, the switch, the LED, and the IC chip were hand-soldered to the PCB.
Not many tools needed here! Just grab your favorite Phillips head screwdriver.
The best size for these small screws is a PH1.
Connect the positive and negative leads to each other.
Press the small black button
Does the red light come on?
Start with either side of the device and unscrew the Phillips head sheet metal screw.
Remove the screw and set aside in a safe place.
Flip over the device to the opposite side and repeat the sheet metal screw removal.
Remove the battery connection on the top of the battery.
Set battery aside
Using the same screwdriver, unscrew one of the top screws that holds in the circuit board.
With the nuts off of the screws, remove the two star washers and set them in your bowl of hardware.
With the nuts and washers off, remove the circuit board from the top shell.
This is a resistor. There are 5 of them on this board!
Here we see the LED.
This is the Texas Instruments IC Chip. It is the brain of the operation.
This is the Panasonic switch.
This is a little diode.
These little spacers keep the circuit board from being smashed against the top shell.
Using the best tool (your fingers) remove the first spacers from the screw.
Sit back and observe your hard work.
Arrange the parts for a nice pic for your portfolio!
