Tools Featured in this Teardown
Remove both T3 screws
Slide off the plastic piece by lifting out and then up
Slide plastic and spring assembly off the rail
Heat the glass screen with a blowdryer to soften the adhesives
Insert a razor blade between the glass and the body
Keep going around the rim of the display until loose
Disconnect vibrator motor
Disconnect heartrate and charging connector
Remove altimeter
Remove motherboard
It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
