This teardown is not a repair guide. To repair your Blackview BV9200, use our service manual.
    1. Blackview BV9200: Teardown, Heating the LCD: step 1, image 1 of 1
      • Begin by heating the LCD. I use a heating pad set to 100 Celsius, and let it heat for 3-5 minutes.
      • If you don't have such a tool, you should be able to use a heat gun. Just heat the edges of the screen.
      • I would not recommend trying to get the screen off without heating the glue.
      Ask FixBot
      • Consider using a more appropriate tool than a part of a box cutter blade to initially separate the LCD from the frame. (I would've tried using iFixit's Jimmy, but I haven't got it yet)
      • Be very careful if you use a part of box cutter blade. You could easily tear the LCD's cables or scratch the underside.
      • Be careful not to separate the LCD and touch panel. When removing the glue with a plastic card, either go underneath the LCD as well or only on the edges of the touch panel.
      • The video is sped up to fit within the 30 second limit. Do it slower and more carefully.
      Ask FixBot
    2. Blackview BV9200: Teardown, LCD's connector: step 3, image 1 of 3 Blackview BV9200: Teardown, LCD's connector: step 3, image 2 of 3 Blackview BV9200: Teardown, LCD's connector: step 3, image 3 of 3
      • Unscrew the screw, remove the tab, unplug the LCD and pull it off.
      • I use tweezers to get the little tab that covers the connector out.
      Ask FixBot
    3. Blackview BV9200: Teardown, Screeeeeeeews.: step 4, image 1 of 2 Blackview BV9200: Teardown, Screeeeeeeews.: step 4, image 2 of 2
      • Many screws.
      • Ones circled in red are all the same size, and ones circled in yellow are the same size as the one which held the tab that covered the LCD connector.
      • After you remove the screws, get leverage on the bottom. You will see a small indent where you can squeeze a tool in.
      Ask FixBot
    4. Blackview BV9200: Teardown, Removing the battery: step 5, image 1 of 3 Blackview BV9200: Teardown, Removing the battery: step 5, image 2 of 3 Blackview BV9200: Teardown, Removing the battery: step 5, image 3 of 3
      • Remove the cover.
      • Remove the cable. Connectors are pointed at by arrows.
      • Disconnect and remove the battery.
      • The battery is not glued or screwed in. Simply grab a hold of it and lightly pull it out.
      Ask FixBot
    5. Blackview BV9200: Teardown, Cat: step 6, image 1 of 1
      • Meow.
      Ask FixBot
DegenFixer
5,750 Reputation
24 Guides authored
1 Guide Comment
How to fix a charger that attach with a phone
Kotua Tatoa - Reply Share
Past 24 Hours: 9
Past 7 Days: 38
Past 30 Days: 134
All Time: 2,703
