This teardown is not a repair guide. To repair your Benro V2 Ball Head, use our service manual.
  1. Benro V2 Ball Head Teardown, The Title: step 1, image 1 of 1
    • Benro V2 Ball Head
  2. Benro V2 Ball Head Teardown, Remove Pan Base: step 2, image 1 of 3 Benro V2 Ball Head Teardown, Remove Pan Base: step 2, image 2 of 3 Benro V2 Ball Head Teardown, Remove Pan Base: step 2, image 3 of 3
    • Loose pan lock
    • Rotate the base, expose and remove all 4 M2.5X5 screws
    • Separate the base
  3. Benro V2 Ball Head Teardown, Remove Pan Lock: step 3, image 1 of 3 Benro V2 Ball Head Teardown, Remove Pan Lock: step 3, image 2 of 3 Benro V2 Ball Head Teardown, Remove Pan Lock: step 3, image 3 of 3
    • Optional, Heat up here
    • Rotate the pan locking knob all the way out, remove the nut. (My screw is broken)
    • The threads on that screw are M5 and M4
  4. Benro V2 Ball Head Teardown, Remove Ball Locking Plates: step 4, image 1 of 3 Benro V2 Ball Head Teardown, Remove Ball Locking Plates: step 4, image 2 of 3 Benro V2 Ball Head Teardown, Remove Ball Locking Plates: step 4, image 3 of 3
    • Remove the locking ring
    • Remove ball locking plates.
  5. Benro V2 Ball Head Teardown, Damping Limiter Cover: step 5, image 1 of 2 Benro V2 Ball Head Teardown, Damping Limiter Cover: step 5, image 2 of 2
    • Remove the cover by rotating it counterclockwise. You might need something to grab it, and/or soften the thread-lock by heating. I drilled 2 holes.
    • Them remove damp limiter screw, using a coin or fingernail.
  6. Benro V2 Ball Head Teardown, Remove Ball Lock Knob: step 6, image 1 of 3 Benro V2 Ball Head Teardown, Remove Ball Lock Knob: step 6, image 2 of 3 Benro V2 Ball Head Teardown, Remove Ball Lock Knob: step 6, image 3 of 3
    • Remove the clip
    • Remove washers
    • Pull off the knob
  7. Benro V2 Ball Head Teardown, The Knob: step 7, image 1 of 1
    • And the friction scale.
  8. Benro V2 Ball Head Teardown, Remove Floating Nut: step 8, image 1 of 2 Benro V2 Ball Head Teardown, Remove Floating Nut: step 8, image 2 of 2
    • Before removing the nut, you may want to remember its position.
  9. Benro V2 Ball Head Teardown, The Large Nut: step 9, image 1 of 1
    • Turn it counterclockwise.
  10. Benro V2 Ball Head Teardown, Ball Locking Screw Small Nut: step 10, image 1 of 2 Benro V2 Ball Head Teardown, Ball Locking Screw Small Nut: step 10, image 2 of 2
    • Heat this nut to ~ 150C, and remove it
    • I forgot to take photo of that.
  11. Benro V2 Ball Head Teardown, Ball Locking Screw and Pushers: step 11, image 1 of 1
    • forgot to take photos. just remove this thing
  12. Benro V2 Ball Head Teardown, Remove Friction Block: step 12, image 1 of 3 Benro V2 Ball Head Teardown, Remove Friction Block: step 12, image 2 of 3 Benro V2 Ball Head Teardown, Remove Friction Block: step 12, image 3 of 3
    • Just remove it
  13. Benro V2 Ball Head Teardown, Remove Arca-swiss Lock: step 13, image 1 of 3 Benro V2 Ball Head Teardown, Remove Arca-swiss Lock: step 13, image 2 of 3 Benro V2 Ball Head Teardown, Remove Arca-swiss Lock: step 13, image 3 of 3
    • Remove the cap
    • unscrew
    • Pull and rotate to remove the knob
    • Then the ball is free. no photo here.
Terrance
6,765 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 398
