This teardown is in progress – Reload periodically to see the latest changes!
Video Overview
  1. Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: step 1, image 1 of 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: step 1, image 2 of 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: step 1, image 3 of 3
    • The back panel is removed.
    • The SSD is removed.
IT FIX
6,340 Reputation
74 Guides authored
12 Comments
Bonjour,
Je n' arrive pas a voir le disque dur de l' ordinateur. Est il accessible?
Peut il être changé ?
schauch - Reply
You mean that you pc can’t see the hard drive? Even in bios?
IT FIX - Reply
Boni can't see it on the video. I d like to buy one of these laptop and change the hard drive for a bigger one. Is it easy to do it?
schauch - Reply
It’s very easy but it’s supports only M.2 SSDs
IT FIX - Reply
Hi there,
I own this laptop, and the internal fan has started to make rattling-like noises, as well as suddenly stopping and starting after a period of watching videos and the like. I am wondering if this is due to dust clogging the CPU fan, and whether compressed air can be used to clean up. If it’s not due to dust clog, what else might be the problem?
Thanks.
Sai - Reply
I am currently having the same problem. I cleaned the fan and there seemed to be no dust when cleaning. After restarting my laptop it continues, I am also curious at to what the problem is.
Leng Her -
Hey,
I have the same problem. Did you fix it?
Leonard •ᴗ• -
Great - my fan is also making rattling noises. I would really like to know how to fix it.
Eike Decker -
I'm having the same problem, will try to clean it and fix the fan, i think it's a fan issue, it should be crooked
David Chong -
Hello, iFixit! What size / number of screwdriver bit (4mm or 1,4’’ Torx (for example T2, T3, T4, T5) ) to open the ultrabook’s case?
Вячеслав Мурзин - Reply
привет, вячеслав мурзин,
давно это было но мне кажется это был t5
IT FIX -
So you have not made any progress from 2018?
Kind-hearted, spirited Man - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 6,440
