This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Aqara G2H / G2H-Pro Camera Teardown
    1. Aqara G2H / G2H-Pro Camera Teardown, Opening the case: step 1, image 1 of 3 Aqara G2H / G2H-Pro Camera Teardown, Opening the case: step 1, image 2 of 3 Aqara G2H / G2H-Pro Camera Teardown, Opening the case: step 1, image 3 of 3
      • Photo 1: remove the 4 short screws located under the camera. The foot separates easily.
      • Photo 2: unclip the 4 bottom snap fits using the opening wheel (yellow arrows). The top snap fits will detach on their own (red arrows).
      • Photo 3: the tools used.
      Ask FixBot
    2. Aqara G2H / G2H-Pro Camera Teardown, Main board disassembly: step 2, image 1 of 3 Aqara G2H / G2H-Pro Camera Teardown, Main board disassembly: step 2, image 2 of 3 Aqara G2H / G2H-Pro Camera Teardown, Main board disassembly: step 2, image 3 of 3
      • Photo 1: remove the 4 long screws (yellow arrows).
      • Photo 2:
      • Unplug the connector using a pick to push the snap fit and gently lift at the same time.
      • Once unplugged, pull the black/red wires out of the notch to release the board. This is the microphone cable.
      • Photo 3:
      • Gently pull the motherboard away from the front shell, being careful of the two metal tabs (yellow arrows).
      • Unplug the infrared lighting module connector (magenta arrow) by pulling on it gently.
      • The black ribbon cable for communication with the camera module is visible (red arrow): it is removed from the main board side by gently lifting the brown flip-lock (orange arrow).
      Ask FixBot
    3. Aqara G2H / G2H-Pro Camera Teardown, Ribbon cable details: step 3, image 1 of 2 Aqara G2H / G2H-Pro Camera Teardown, Ribbon cable details: step 3, image 2 of 2
      • Photo 1: the flap that serves as the ribbon cable lock is lifted (orange arrow).
      • Photo 2: the ribbon cable is directional!
      • "TO-MAIN" plugs into the main board side.
      • "TO-SENSOR" plugs into the camera module side.
      Ask FixBot
    4. Aqara G2H / G2H-Pro Camera Teardown, Camera module disassembly: step 4, image 1 of 2 Aqara G2H / G2H-Pro Camera Teardown, Camera module disassembly: step 4, image 2 of 2
      • Photo 1:
      • Remove the 3 short screws (yellow arrows). Do not remove the other two screws holding the lens to its board.
      • Using a small pick, gently lift the circuit board at the visible white pins (purple arrows).
      • Photo 2: camera module removed next to its base.
      Ask FixBot
    5. Aqara G2H / G2H-Pro Camera Teardown, Infrared light disassembly: step 5, image 1 of 2 Aqara G2H / G2H-Pro Camera Teardown, Infrared light disassembly: step 5, image 2 of 2
      • Photo 1: remove the two screws (00) that hold the infrared diode board in place.
      • Photo 2: infrared module removed. You can see the diodes.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Attached Documents
Madcat
1,340 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 70
All Time: 499
