This teardown is not a repair guide. To repair your Akai MPC Sample, use our service manual.
  1. Akai MPC Sample Teardown, Remove the front knobs and faders: step 1, image 1 of 1
    • Alright. Depending on how deep you're intending to get into the device, you will need to remove the three knob caps, the fader cap, the master encoder knob (you'll also need a wrench as the potentiometer for this is held in place by a threaded nut).
    Ask FixBot
  2. Akai MPC Sample Teardown, Remove the 5 screws on the back: step 2, image 1 of 2 Akai MPC Sample Teardown, Remove the 5 screws on the back: step 2, image 2 of 2
    • There are 5 screws on the back. They are phillips screws, pretty easy.
    Ask FixBot
    • 3 of the sides are pretty easy to pop open with the guitar pick shaped plastic devices, but the last side (the bottom) has a series of 4 or 5 tabs held in place by friction. I was able to pry them up via a plastic spudger
    Ask FixBot
  3. Akai MPC Sample Teardown, Remove the battery.: step 4, image 1 of 3 Akai MPC Sample Teardown, Remove the battery.: step 4, image 2 of 3 Akai MPC Sample Teardown, Remove the battery.: step 4, image 3 of 3
    • Battery is held in place by 4 screws. Same size as all the other screws I ran into. Remove those, unplug the battery from the plug, good to go.
    Ask FixBot
  4. Akai MPC Sample Teardown, Remove the upper board first.: step 5, image 1 of 2 Akai MPC Sample Teardown, Remove the upper board first.: step 5, image 2 of 2
    • Okay this part's tricky. There's several screws to remove, that's fine, but there's also a ribbon cable that is threaded through a slot on the board, and then wrapped around a piece of plastic, and THEN adhered to the board with adhesive foam tape. Unplug the ribbon cables, pry off the plastic thing and the foam tape (BE CAREFUL)
    Ask FixBot
    • After unplugging the speaker, removing the screws, and untangling and unplugging the ribbon cables, you will need to pry up the knob for the volume knob on the top of the unit. There's a cutout in the board that you can fit a plastic prying tool in to pry up the knob.
    Ask FixBot
  5. Akai MPC Sample Teardown, Remove the upper board: step 7, image 1 of 1
    • Lift upward. It's a finicky fit but it will come up so long as you have everything disconnected. BE CAREFUL. The ribbon cable that was wrapped around the plastic loop has kinks in it and can be caught on the slot, feed it through carefully to remove the board without damage.
    Ask FixBot
    • This is as far as I got. I'll leave additional findings in the next steps. The ribbon cable for the screen looks especially fragile.
    Ask FixBot
    • Ok, even if you remove the fader and all the screws, there's a fragile ribbon cable connecting the fader board to the bottom board. Both boards must be removed at the same time so as not to rip that tiny hidden ribbon cable. You must remove the fader and three knobs above the pads to acheive this.
    Ask FixBot
    • Yup, so if you have to replace this little battery, get a CR1220 3v button cell.
    Ask FixBot
    • I'm immobile and couldn't access anything other than my little electronics screwdriver kit for this teardown. You should be able to access everything after you get the two main boards out, but I didn't go past that. If someone else wants to make a more in depth teardown I'd appreciate it.
    Ask FixBot
Zachariah Slawik
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 121
All Time: 135
