This teardown is not a repair guide. To repair your Airvape Legacy Pro, use our service manual.
  1. Airvape Legacy Pro Quick Teardown, Airvape Legacy Pro Quick Teardown: step 1, image 1 of 1
    • Remove the top cloth material with heat
    • The tape that holds the fabric is no longer sticky after removal. But I found that heating it up again and reapplying the fabric works!
    • Remove four Phillips head screws
    • Use a spudger to lift off the plastic panel
  2. Airvape Legacy Pro Quick Teardown, Angled look at PCB: step 2, image 1 of 1
    • Just another photo
  3. Airvape Legacy Pro Quick Teardown, Under wireless charger: step 3, image 1 of 1
    • The wireless charging coil sits on a sticky pad, can be easily lifted with tweasers
  4. Airvape Legacy Pro Quick Teardown, Tear appart internal parts: step 4, image 1 of 3 Airvape Legacy Pro Quick Teardown, Tear appart internal parts: step 4, image 2 of 3 Airvape Legacy Pro Quick Teardown, Tear appart internal parts: step 4, image 3 of 3
    • Loose the two screws and gently tear appart the internal plastic body from the external metal case
ShellingRook27
2,005 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
12 Guides authored
5 Guide Comments
Looking forward to seeing this continue!
andypapster - Reply
nothing more with the teardown?
seedy53 - Reply
I think on FC he mentioned this was still his primary device and until he replaces it, he won’t do a further tear down.
andypapster -
Yeah, that is all for now. Like Andy said I'm still using this device and will do a full destructive teardown when I replace it. I'll update the introduction with that information.
ShellingRook27 -
I'm curious to know what kind of plastic is used in the construction of this device? Is it high grade PEEK good for a working temperature between 480°F and 500°F without off gassing, V.O.C.s? My air Vape Legacy Pro after 12 months of use, the vegan leather and hemp decals have delaminated from the plastic housing!
Please note it doesn't matter if it's food grade food grade plastic, which is mainly used for plastic bottles and storage containers Etc. Don't make the mistake I did, please avoid this purchase! Unless you're into off-gassing plastic into your system! After doing some research Air Vape will not confirm what plastic they're using! Extremely disappointing!
My DaVinci iq3 isn't without issues but at least it's made with premium parts using Aluminum, Stainless Steel and Zirconia
Ceramic! I have a brand new Apollo Legacy Pro in the Box any takers
$120 + shipping! U.S.A. only
Ghost Believer 👻
ghostbelievermv1gmail.com
-Ghost Believer- - Reply
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 87
All Time: 1,607
