This teardown is not a repair guide. To repair your Acer Liquid E1, use our service manual.
  1. Acer Liquid E1 Teardown, Acer Liquid E1 Teardown: step 1, image 1 of 1
    • Remove the plastic back and the exposed battery.
    • Do not forget to remove sim- and SD-cards
    • Use a torx t5 to unscrew all screws. This will be the first and last time you'll use a screwdriver with this device.
  2. Acer Liquid E1 Teardown: step 2, image 1 of 2 Acer Liquid E1 Teardown: step 2, image 2 of 2
    • Use a plastic opening tool or spudger
    • Pry around the side to release the backframe from the middleframe
    • Be careful as the frame is quite fragile
  3. Acer Liquid E1 Teardown: step 3, image 1 of 3 Acer Liquid E1 Teardown: step 3, image 2 of 3 Acer Liquid E1 Teardown: step 3, image 3 of 3
    • To free the main board, remove the connector and antenna-cable
    • Use a plastic spudger
    • Be careful not to chip components
  4. Acer Liquid E1 Teardown: step 4, image 1 of 3 Acer Liquid E1 Teardown: step 4, image 2 of 3 Acer Liquid E1 Teardown: step 4, image 3 of 3
    • Tilting the main board will reveal this connection
    • Use a plastic spudger to open the lock
    • Carefully pull the flex cable out of it
    • Don't put alot of stress on it
  5. Acer Liquid E1 Teardown: step 5, image 1 of 3 Acer Liquid E1 Teardown: step 5, image 2 of 3 Acer Liquid E1 Teardown: step 5, image 3 of 3
    • At the bottom, use a pair of tweezers to remove the yellow tape from the connector
    • Use a plastic spudger to unlock
    • Pull the flexcable out carefully
  6. Acer Liquid E1 Teardown: step 6, image 1 of 2 Acer Liquid E1 Teardown: step 6, image 2 of 2
    • Next, use a platic spudger to remove the flex cable from its connection
  7. Acer Liquid E1 Teardown: step 7, image 1 of 3 Acer Liquid E1 Teardown: step 7, image 2 of 3 Acer Liquid E1 Teardown: step 7, image 3 of 3
    • Use a spudger to remove the bottom-plate from the frame.
    • Be careful when using metal tools (like I did)
    • Make sure the antenna cable isn't attached to anything except it's socket
  8. Acer Liquid E1 Teardown: step 8, image 1 of 3 Acer Liquid E1 Teardown: step 8, image 2 of 3 Acer Liquid E1 Teardown: step 8, image 3 of 3
    • Let the remaining heat at 95°C for about 3-5 minutes to soften the adhesive
    • Use an opening tool to pry at the top, between your digitizer and the middleframe
    • Open it from the top, your digitizer-flex runs at the bottom
    • Be careful when using a heat-gun. Heat-guns don't distribute heat evenly and LCD-burns may occur
  9. Acer Liquid E1 Teardown: step 9, image 1 of 3 Acer Liquid E1 Teardown: step 9, image 2 of 3 Acer Liquid E1 Teardown: step 9, image 3 of 3
    • To remove the LCD, remove the sticker on the back of the midframe. It conseals the LCD-flex
    • Be careful when removing the sticker. It's glued tightly and too much stress will tear the LCD-flex
    • Remove the LCD by pulling the whole cable through the midframe.
  10. Acer Liquid E1 Teardown: step 10, image 1 of 1
    • All done
    • I hope you enjoyed it as much as I did
Maxim
2,297 Reputation
3 Guides authored
iFixers Belgium Member of iFixers Belgium
Business
1 Member
5 Guides authored
One Comment
Great Manual.. it work fine! thanks,,
JoeTech - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 24
All Time: 6,771
