Shop the Holiday Gift Guide
Introduction
Go to step 1 ↓
This is the ACEPC AK2 and on the Mainboard you can read AK1 V6.0.
Tools
This teardown is not a repair guide. To repair your ACEPC AK2 (AK1V 6.0), use our service manual.
    1. ACEPC AK2 (AK1 V6.0) Teardown, Open the Top - SATA Connector - Drive - SSD - HDD: step 1, image 1 of 1
      • You only need the screwdriver if there is a screw in the red circle. I used the screwdriver to show you how the lid is fit.
      • Remove the power adapter
      • Slide the release button to the right.
      • Now you can lift the top and put it to the side.
      Ask FixBot
    2. ACEPC AK2 (AK1 V6.0) Teardown, How to release the silver frame.: step 2, image 1 of 3 ACEPC AK2 (AK1 V6.0) Teardown, How to release the silver frame.: step 2, image 2 of 3 ACEPC AK2 (AK1 V6.0) Teardown, How to release the silver frame.: step 2, image 3 of 3
      • Release the screws of the frame.
      • You can release the screws of the drive frame ...
      • ... or leave the screws in place and pull off the black tape.
      • You need the longer screwdriver for some screws
      Ask FixBot
    3. ACEPC AK2 (AK1 V6.0) Teardown, Motherboard - Mainboard: step 3, image 1 of 1
      • Now release the screws in the orange sircles.
      • Better release the screws on the LED board.
      • slide the board a little bit away from the outer connectors and pull it up.
      • Please dont break the walls.
      • The battery gives the board a little bit electric power. Please dont get a electric shock.
      • The antenna (in blue) is very sensitive and can easily tear off. You can carefully peel the foils with the antenna & stick them onto the black cover of the board.
      Ask FixBot
Author
with
Alex Barblexi
347 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 100
All Time: 2,944
