Introduction
Deconstructing processors like the A4 usually happens behind the closed doors of only a handful of companies. These global reverse engineering firms are the investigative arm of the electronics marketplace, gumshoes who do research for people who need to find out who is making what circuitry, as well as what manufacturing process they're using to do it. They're the ones who delve deep into processors, audio controllers, and every other part you'd find inside a cell phone or iPad, figuring out layer by layer the exact composition of each package.
We partnered with the best company in the semiconductor reverse engineering trade, Chipworks, to bring you a closer look at how semiconductor teardowns are conducted, as well as a peek inside the iPad's chips. The engineers at Chipworks are a wonderful bunch of people who are just as interested in today's electronics as we are.
Their analysis of the iPad's packages will give you a better understanding of how the new tablet really works—on an almost molecular level.
This teardown is not a repair guide. To repair your iPad Wi-Fi, use our service manual.
  1. Apple's A4 microprocessor is the brain of the iPad.
    • Apple's A4 microprocessor is the brain of the iPad.
      • The A4 is an ARM processor featuring package-on-package construction to improve the speed and efficiency of internal processes.
    • The silkscreen on the A4 reads N26CGM0T APL0398 339S0084 YNL215X0. But that's not very interesting—those numbers don't mean much to us, either. Let's see what we can find inside.
    Cool teardown!
    Morgan - Reply
    There's an Atmel 8 Megabit flash chip in there that Chipworks couldn't figure out:
    http://www.atmel.com/dyn/products/produc...
    Morgan - Reply
    Looks like it's official, the iPad IS just a giant iPod Touch. Nothing special here, move on.
    But nice work on this teardown, was cool to look at how these "micro-teardowns" are done.
    rab777hp - Reply
    The APL0398 is Apple internal part number designation of new A4 SoC, one can find it on the die and within markings on the package.
    The A4 predecessor found in iPhone 3GS is designated as APL0298, so A4 could be just next, optimized, version of APL0298 :-)
    Dimitar - Reply
    I want to get this faulty iPad.
    Most likely you do not need in it.
    I understand, that this ain't based on repair.
    Dmitry - Reply
  2. Back when the original iPhone came out, we worked with some friends of ours in Silicon Valley to dissect the processor. The equipment we used wasn't nearly as cutting-edge as what Chipworks has, but it got the job done.
    • Back when the original iPhone came out, we worked with some friends of ours in Silicon Valley to dissect the processor. The equipment we used wasn't nearly as cutting-edge as what Chipworks has, but it got the job done.
    • This is a silicon wafer. Each small square is a chip, called a die. The processor die in the A4 is 7.3 mm on each side, for a 53 square mm total area. The percent of working dies that you can get from a wafer like this is called the yield.
    • The A4 is actually much more than just a processor— it's a Package on Package, or PoP. In fact, there are three silicon dies inside the A4!
    too many different kinds of dies to keep straight, neat to see tho
    ronenhackim - Reply
    • Our illustrious leader preparing to enter a cleanroom for some silicon surgery on the original iPhone.
    • You have to first remove the processor from the main board before dissecting it.
    • There are only two ways to remove a processor from a circuit board: Extreme force and extreme heat. Guess which approach we used?
    • Next, cut the processor in half to take a cross-section photo.
    • Band saws are much too crude for this, so we actually grind through the processor slowly, taking off very small amounts of material as we go.
    • You can see why it can be tough to take a clear, solid photo of a package's cross-section. The processor is actually one of the larger packages in the iPhone, and still very finicky to handle. Imagine trying to do this with a package a tenth of its size.
    • So what is a package? You're looking at one.
    • This is a cross-section of the iPhone's ARM processor + RAM package. Click here to see it in its full, 2854x313 glory.
    • The processor itself is the center rectangle. The silver circles underneath it are solder balls.
    • The two rectangles above the processor are RAM dies. They are offset from each other to make room for the wirebonds, which you can't see in this shot.
    • Having the RAM so close to the processor both reduces latency—making RAM access faster—and cuts power consumption, helping your battery last longer.
    • This is our friend's workbench. We're also huge fans of Weller.
    • These are the the types of tools that'd make MacGyver proud... Although we suspect that all he'd need is a paperclip and two strips of duct tape to take apart the processor.
    • This is a typical cleanroom. Regular people—people who might even shop at the same supermarkets as you—suit up every day and go to work in rooms like these. It's absolutely imperative to keep dust, lint, and hair away from the task at hand.
    • Tools of the trade:
      • Scanning electron microscopes
      • High resolution X-ray machines
      • Really big magnifying glasses and microscopes
      • A number of other gadgets you might find in Q's lab
    • If only all safety violations were this easy to fix!
    Is it just me, or this is an OS/2 system? Cool! ;)
    mainyehc - Reply
    "The equipment at Chipworks is quite different than you'll find in most semiconductor facilities"
    I work for a large semi-conductor company... one with many -intelligent- people (wonder if you deciphered my code), we have all these tools for tearing down our products to find faults and improve yields. I assume that most, if not all semiconductor facilities have these. good article!
    Dave - Reply
    Is that IRIX? :D
    SteveGates - Reply
    Quote from mainyehc:
    No, that is definitely a Motif-based UI, so probably some flavor of Unix, perhaps even IRIX as one commenter said. Many of the other computers are using just Windows :-)
    kerneljack - Reply
    • Chipworks is based in Ottawa, Ontario. It gets so cold there that your tires can actually crack if you're not careful.
    • The equipment at Chipworks is quite different than you'll find in most semiconductor facilities. Every single machine they have exists with one purpose in mind: discovering what's inside the latest chips.
    Tire cracking due to extreme cold... just a myth ;-)
    Bernard Maltais - Reply
    Can you tell me the package dimensions and ball pitch please? I can't see a scale in any of the images (unless the grid in step 15 is 1mm?).
    Hugo Vincent - Reply
    Package appears to be 14 x 14 mm with 0.5 mm BGA pitch
    Doug Powell - Reply
    • Microscope analysis, both of the optical and SEM kind. Either one is definitely not your typical community college biology lab unit.
    • Precision matters in this business, and Chipworks is known to be very precise.
    • A scanning electron microscope (SEM) in action. These are just some of the tricks up Chipworks' sleeve. The SEM is able to see hundreds of times more detail than an optical microscope.
    • Grinding down a package. Keeping the part level as you grind is critically important.
    • This process is incredibly painstaking. There's actually a fine art in grinding to exactly the right spot for the photo while keeping the surface perfectly level.
    • We (at iFixit) are terrible at this. That's why we shipped our iPad to Chipworks.
    • The next step is to remove the outer packaging.
    • Tea time? Nope, just time for a nice acid bath.
    • Dipping the processor in acid dissolves the ceramic packaging containing the silicon. Using the appropriate concentration of acid for the type of ceramic packaging is critical.
    • Every once in a while, looking at a die yields nifty surprise hidden by the manufacturers. Alas, Milhouse was not found in the iPad. But he was recently discovered inside a Silicon Image chip!
    • Alright, now you know how we did it. But what does the A4 look like inside?
    • Photos of the top and bottom of the A4 package.
      • Those tiny dots you see on the underside are solder balls that adhere the processor to the logic board. They transmit all power, grounding, and information to-and-from the processor and board.
    • Before dismantling it, Chipworks took an X-ray image of the A4 processor to get a feel for how things are laid out inside.
    • If you look closely, you can see hundreds of thread-like interconnects (wirebonds) that carry electronic signals between dies.
    • The A4 has three layers: Two layers of RAM (Samsung K4X1G323PE), and one layer containing the actual microprocessor.
    • This Package-on-Package construction gives Apple the flexibility to source the RAM from any manufacturer they want—they're not locked into Samsung.
    I'm not if I completely understand the point below and would appreciate some elaboration.
    "This Package-on-Package construction gives Apple the flexibility to source the RAM from any manufacturer they want—they're not locked into Samsung."
    I understand that PoP construction makes it technically feasible for to combine logic and memory chips from different makers. However, does this ever really happen with Samsung? I feel it would be unlikely that the logic maker (Samsung) would allow Apple to use anyone else's memory, given that Samsung makes both logic and memory. Can anyone share their experience?
    Colin Boyd - Reply
    • Here are two side X-rays of the A4 processor.
      • The dark dots along the inside of the processor are solder balls connecting the dies together. These are known as Ball Grid Arrays (or BGAs) in the industry.
    • These pictures are shot at two focal points across the width of the processor. They were quick shots, so we apologize if they're a little fuzzy.
    • The DRAM in the A4 is made by Samsung, so wirebonds are coming from both sides—unlike other DRAM modules Chipworks has seen from other manufacturers.
    • This is a die metal 8 layer.
    • Every iPhone processor that we have dissected has had a Samsung part number on the processor die. We have not found any Samsung markings on the A4 (outside of the DRAM), perhaps the clearest sign to date that Apple is in firm control of the semiconductor design.
    • We don't expect to find any markings from PA Semi, Apple's recent acquisition, but it's safe to assume they played a major role in designing this package.
    • This is the SDRAM inside the A4. Yes, that's a Samsung logo. No, that doesn't mean Samsung designed the A4—just the RAM.
    • Samsung's 1 Gb mobile DDR SDRAM (x2)
      • The part number on each die is K4X1G323PE.
      • Decoding this part number shows there is 2Gb of memory inside. This translates into ~128MB of memory per die, for 256 MB total.
    Hey, you might want to let WSJ know about this, I read an article in which Kyle Wiens gave an interview about the A4 and I remember it clearly stating that samsung made/designed the A4. May want to correct them on that.
    rab777hp - Reply
    The exact quote in the article is "The proximity of the chips suggests that Samsung also manufactured the A4 for Apple." I think that's a fair assessment. Hopefully we'll find out tomorrow for sure.
    Kyle Wiens - Reply
    Manufacturing (fabricating) is different from designing. Samsung might have very well manufactured the chip for Apple, since Apple doesn't own any fabrication facilities. Apple designed the chip and Samsung fabricated it for them. Make sense to me.
    com ctrl6 - Reply
    Quote from Kyle Wiens:
    Ah, ok, I was misremembering the article then. Thanks for the clear up.
    rab777hp - Reply
    Any further information on the manufacturer of the SOC?
    mwhibben - Reply
    "Decoding this part number shows there is 2Gb of memory inside. This translates into ~128MB of memory per die, for 256 MB total"
    I'm sorry for being a noob, but I don't understand this sentence. If there is 2GB of memory inside how is there a total of 256MB?
    Watt - Reply
    Quote from Watt:
    GB is gigabyte, Gb (lower case b) is gigabit. 8 bits = 1 byte.
    Chris Cline - Reply
    Quote from Chris Cline:
    Thank you. That makes sense. I appreciate the info.
    Watt - Reply
    Watt - Reply
    luwoze - Reply
    The author was ambiguous - if your unit of measurement is in 'bits', it should be the same unit throughout the text (and it's equivalent in 'Bytes' given in parenthesizes).
    luwoze - Reply
    Quote from luwoze:
    Well know, because different things are measured in different units.
    rab777hp - Reply
    • So now that we've seen the inside, what can we conclude?
      • There's not much revolutionary here. In fact, the A4 is quite similar to the Samsung processor Apple uses in the iPhone.
      • It's clear from both hardware and software that this is a single core processor, so it must be the ARM Cortex A8, and NOT the rumored multicore A9.
      • It's quite challenging to identify block-level logic inside a processor, so to identify the GPU we're falling back to software: early benchmarks are showing similar 3D performance to the iPhone, so we're guessing that the iPad uses the same PowerVR SGX 535 GPU.
      • The iPad has 256 MB RAM, same as the iPhone.
      • The A4 sips power. In fact, power consumption is probably the reason Apple hasn't stepped up performance much from the iPhone. In order to get 10 hours of battery life, the entire iPad (including display) has to pull less than 2.5 Watts on average.
    • That's it for the A4. Let's take a look at some of the other chips inside the iPad.
    • Capacitive touchscreen controller.
      • Broadcom BCM5974
    • Broadcom's I/O microcontroller with NVM (used for touchscreen)
      • Broadcom BCM5973KFBGH HS0951P11 952280 B1
      • Apple 343S0446
    • The Texas Instruments touchscreen line driver.
      • CD3240A 01D5AKT G1
    • Broadcom 802.11a/b/g/n WiFi + Bluetooth 2.1 + EDR and FM.
      • Broadcom BCM4329XKUBG CD1004 P21
    • Cirrus Logic device – suspected audio processor.
      • Apple 338S0589 B0 YFSAB0PY1001
    • Suspected power management.
      • S6T2MLC N2266XQT U1003 A1
    • Mux/demux part for DisplayPort and PCIe connections.
      • NXP L0614 01 37 ZSD950
    "DisplayPort and PCIe connections" Could it be an interconnection for the 30-Pin adapter or its is just inside the logic board?
    Vrumm - Reply
    • Display.
      • LG SW0627B 01SWL-0032C 1003 N23977ON
    • Apple 338S0805 A2 e1 10028HBB
    Dialog Semi out of the UK. Power management?
    rburnettcpa - Reply
    • Accelerometer (confirmed by die markings of ASIC and MEMS device) - STM-LIS331DLH.
      • STMicroelectronics 2949 33DH OK2 CL
    How does the STM-LIS331DLH Accelerometer works? Is the only electronic sensors or those it have some micro-mechanical parts?
    Vrumm - Reply
    • DC-DC regulator.
      • Linear Technologies 3442 N7667 LT9L
    • Intersil i976 45AIRZ F95OHX
    The exact PN of Intersil IC should be ISL97645AIRZ.
    "Boost + VON Slice + VCOM", according to datasheet.
    Dimitar - Reply
    • That's what we've got so far. We'll add more photos as Chipworks posts more.
    • We'd like to thank our friends over at Chipworks for their exceptional work.
    • Don't forget to take a peek at our iPad Teardown for a complete disassembly.
    Except for the WiFi chip, all others are from 2007 (or before), so Apple had this going on for some time.
    Edis0n - Reply
    Quote from Edis0n:
    Probably not, these chips were most likelly used in older iPods, and provide legacy support (Since AAC Encoding hasn't changed much i the past 5-7 years) and the touch drivers were most likelly for the older iPods and iPhones, with slightly different instructions.
    Chris Green - Reply
    Quote from Edis0n:
    Yes, they probably have been thinking about the iPad for some time, but I don't think the chips used are old because of that. If the chips do their job it makes sense from a cost perspective to use components that have been in production for a while, and thus are cheaper. Especially considering that the A4 must have cost Apple quite a bit to design and get made.
    Pio - Reply
0 Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 99
All Time: 275,388
