My Problem
During the prep for my sob's Bar Mitzvah we discovered that my wife's Macbook Pro had a very small amount of hard drive space. The home made montage filled it! Plus it was running very slow due to lack of space.
My Fix
I looked online, ordered the 1TB sata drive and kit. Printed the instructions. The repair went perfectly! Easy peasy. Just follow to the letter.
My Advice
A few tips:
1.Tape down on a piece of paper the screws from the unibody. They are very small.
2. Buy an external case and put the new HD in first the connect it via usb and use carbon copy cloner to clone your drive. It will also make a mavericks recovery partition. Then reboot holding the option key. Make sure the drive boots, then do the physical swap. Keep the old HD in the case of any problems. I installed it in the external case for usb access.
3. Be gentle with the T6 torx screws when removing them from the old HD. Dont strip them as they hold the drive in place.
0 Comments
