« Back to All Stories
How I fixed my airport/bluetooth
kristanslack -
MacBook Pro 13" Unibody Mid 2012
MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement
20 - 30 minutes
Moderate
My Problem
After replacing my macbook pro hard drive with an ssd one my airport/bluetooth failed on my computer. Probably because I broke something internally when I took it apart in the first place. No amount of software changes or restarts fixed it.
My Fix
Easy as.
I bought each component - helps that fixit supply them all - to remove any possibility of failure (cable, bracket, chip) and to reduce the number of times I had to do this.
Worked immediately after I'd replaced all the parts and I've had no problems since.
My Advice
Be careful when swapping SSDs and trying to remove optical drives. My mistake was in trying to remove the optical drive I was over zealous and probably broke some part of the wifi then.
Doingthe actual wifi repair was simple. Just be careful with pulling back the EMi tape and re-taping it back on.
Spudger Image
Spudger
$3.99
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board Image
$42.99
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Cable Image
$9.99
0 Comments
