« Back to All Stories
Screw Driver
James Borchardt -
My Problem
Needed battery for my Honda key fob
My Fix
This key fob requires the removal of an extremely small phillips screw to separate the key fob to access the battery; I had a couple of small screw drivers on hand and proceded with them but could not break the screw lose. I started rounding the phillip + out and thought oh s**t I’ve done it now. So I found your Webb site and found your fix for this task along with your wonderful German #0 Phillips screwdriver. I ordered and received the screwdriver then rested the key on a solid surface in order to apply sufficient pressure on the screw as I turned it. It worked!!! I could not have done it without your wonderful screwdriver!
My Advice
Don’t round out the + from the head of a Phillips screw; use a good screwdriver
Phillips #0 Screwdriver Image
$5.49
0 Comments
