My Problem
Battery was showing 1300-1400 mAh and it was supposed to be at 1715 mAh. Basically I wanted to check if replacing the battery would increase the speed of the phone as apple claims.
My Fix
It went ok. Took a little time to start to separate the case and get the adhesive off the case. Had a small issue with the battery adhesive backing coming off then resticking and being a pain to get off with out ruining the strips. Also had problems with the case adhesive being a pain to line up on the case. In the end I am happy. Like anything else if I did this again it would go much easier.
My Advice
Make sure to follow the procedures for installing the battery. Hook the battery terminal up before putting the battery in the case and then disconnect it so that you can reconnect the screen. Just follow all the instructions and read through them before you start.
0 Comments
