My Problem
the battery was dying within a few hours.
My Fix
smoothly.
My Advice
i bought the tape kit from ifixit. its good for 2 corners, so i added a little bit more 2 sided tape. its not as good quality, but it should be better then nothng.
you will also want a microfiber and alcohol so you can clean the back panel off since it will have glue residue on it.
i did buy the microwavable pad, it worked perfectly, never needed to turn on my heat gun.
i used the heat pad on it for a minute, then the i slack to pull it apart just enough to run the halberd spudger into a section of it. i then used an opening pick into the area the spudger loosened.
i repeated the spudger and pick all the way around. i had to reheat the pad 2 more times as i did this and move it around.
0 Comments
