My Problem
After the iOS 11 update for iPhone I’ve had the same battery drain issue everyone else has due to apples greed and negligence. So I ultimately don’t trust them to fix my phone when they can pull such a shady stunt as they did, not to mention I prefer to do the job myself so I know what’s been done.
My Fix
The overall Repair went well, the repair manual was very detailed and to the point. The only issue I had with it was the gasket holding the front case on was matted to the clips to the left side and when I went to pry up a little the screen cracked pretty bad so had to order that too.
My Advice
Warm up around the phone to soften the adhesive inside and make sure you have it severed from the casing 100% before you try to lift up on the screen area or damage will occur.
0 Comments
