My Problem
Phone was getting slow, cheap battery replacement option.
My Fix
Quick and fairly easy. No major issues.
My Advice
When initially trying to separate the screen/chassis I had to use a blow dryer to heat the area to loosen the adhesive.
The battery adhesive “pull tabs” all ripped before complete removal making the original battery problematic to remove. I ended up using the blow dryer to heat the underside of the back and used the pry tool to work the battery loose.
0 Comments
