My Problem
The battery was loosing power very quickly.
My Fix
Removing the old battery went very smoothly. I did have difficulty putting the upper screw , the 1.5 mm Phillips screw, back into its hole. The upper hole in the battery connector was not perfectly lined up with that hole after the connector was snapped into place. I eventually got it in but had to press it in to get the thread started and I may have stripped the head of the 1.5 mm Phillips head screw. The connector and the ground clip are secure and in place and when I reassembled the phone, it started right up. Everything is working properly. Thank you for your help.
My Advice
Be patient.
0 Comments
