« Back to All Stories
HD cable + drive replacement
Daryn White -
MacBook Pro 13" Unibody Mid 2012
MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
50 minutes
Moderate
My Problem
I've previously had Apple repair the cable while it was under warranty and that cable subsequently went out about a year after that. I was able to scavenge a HD cable from another MacBook Pro (mid 2011) and while not ideal, it worked well enough. Now I had the money and time to double down on the cable and leap the HDD space.
My Fix
The repair went great. I was able to install macOS on the new drive prior to opening the case and test it via a USB3 HD sled I have, though the one from iFixit would have worked as well. After opening the cases and removing the IR bracket from the proper cable the rest was a breeze. The instructions were easy to follow and gave me confidence when I had a question.
My Advice
If you don't have a solid set of tools for working on electronics, get one from here.
Essential Electronics Toolkit Image
$19.99
0 Comments
