My Problem
Battery was draining on no time at 386 cycles!
My Fix
I took a serious shortcut and saved a ton of time and effort on this repair. Found some heavy duty mono-filament in the studio, tied the ends to some 1/2" square dowel rod sections, and taped the handles for comfort with some gaffers. I believe this is referred to as a garrote, used in film for silent mafia stranglings.
I didn't remove the fans, motherboard, or anything other than unplugging the old battery and taking off the two battery terminal screws.
I just tucked the mono-filament behind the top corners of each battery cell, then held down the computer and slowly cut through the adhesive by pulling forward. I found pulling one side while holding tension on the other was more effective than trying to pull both at once. About half a dozen strokes and the cell popped up, and I used a card to snap the last bit of adhesive at the bottom. Repeated for all 6 cells, being especially careful around the one with the track-pad cable. It took about 10 minutes to remove the old battery.
Removing glue residue, on the other hand, took a good portion of an hour, a little at a time, using smalls squirts of adhesive remover to avoid spills. I started with the guitar pick, then the iFixit cards, then moved on to the spudger, which worked best by far.
My Advice
Make a garrote and cut the adhesive.... super effective!
0 Comments
