My Problem
iPhone 5S battery replacement
My Fix
The repair was fine. The battery was a pain in the neck to remove, and some of the cables were a little tricky to disconnect. All in all, it went well.
My Advice
Be careful while handling the screws. I was holding a small screw with my tweezers and it snapped and flew out on to the floor. If you break the tabs while pulling out, use the tweezers to pull them out, and pull them as parallel to the working surface as you can.
0 Comments
