My Problem
Had some damage to the track pad that had some shattered glass in the corner. It also had some issues with occasionally going haywire, even before the shatter, where it the cursor would start doing random things on the screen.
My Fix
Repair was super easy - I've opened up my mac before to replace the fan, upgrade RAM, and switch to SSD.
The only problem I had was with the tiny screws on the track pad, the metal clip that the screws were attached too was very flimsy and easily bent as I was trying to remove the screws and then later put them back in. The result was that the left corner is not as flush as I'd like it to be, but otherwise it works perfectly fine.
My Advice
Mostly it's easy, just be cautious on the clip.
0 Comments
