My Problem
Swollen, weak battery
My Fix
The battery replacement went without a hitch! A piece of cake.
My Advice
The screws holding the battery connector In place are very small and difficult to work with. Be very careful, if you drop one, I am sure you will never find it. Note: spare screws are provided for fasting the touchscreen to the case. I would suggest that replacement screws for the battery connector be supplied also--just in case. Since my battery had swollen up the screen was being separated from the case making it a breeze to fit the supplied pry tool between the two and separating the screen from the case. I did not find a need to disconnect the screen cables from the case. Although the battery was pretty well stuck to the case it came out with careful prying--no heat needed.
0 Comments
