My Problem
iPhone 5 AT&T has no sound only with headphone
My Fix
Got the part fast repair went OK (next time buy magnified glass too) the screw are very tricky too small be careful not to loose them, the i fixit are good but the part didn't solve my problem and I ended to order the main speaker too.
My Advice
if you are not comfortable doing this job don't start give it to a friend with tech experience
2 Comments
you mite need to replace the battery if taking it out will bent or crack it , damaged battery can catch on fire
shtekler - Reply
you mite need to replace the battery too, if during the process you need to remove it cracked or bent one can catch on fire
shtekler - Reply
