My Problem
Jammed DVD drive
My Fix
Repair worked well. Required skills and patience I was in short supply of. I broke one of the side faceplates. Moving the board from one DVD drive to the other proved to be quite an exercise. Took a great deal off time. I would recommend practice on soldering. Solder on the other side of the board !!! The motor wires solder after joining.
My Advice
-cut the wires on the opposite end of the needed part. Save the most amount of wire you can.
-Solder on the other side of the wire than on the board. That is easier.
-the motor wires will need to be connected rather than soldered at the end
0 Comments
