My Problem
My lightning connector was loose so I would have to wiggle the cord to get it to charge.
My Fix
The repair went great
My Advice
1. Be careful, when pulling the mic, the double sided tape/adhesive pulled away from the phone. If I hadn't looked and carefully readjusted it, it would have been wrinkled when reapplying the mic and would've got smashed into the mic hole (blocking the sound)
2. After 10 minutes of frustration trying to reconnect the antenna I had to WALK AWAY for 5 minutes to come back and spend 5 more minutes to get it popped on.
3. I skipped the steps to seperate the glass and left it hinged at the top and propped against a lamp with a slight angle back. You could use a "loose" rubberband to strap it up to small item so it won't move or fall over.
4. Make sure you have a magnetic screwdriver on the inside screws. I had one but this would be PAINFUL without one.
0 Comments
