« Back to All Stories
Not as bad a I thought.
john -
iPad 3 Wi-Fi
iPad 3 Wi-Fi Battery Replacement
1 - 3 hours
Difficult
My Problem
The battery was not holding a charge.
My Fix
Initially, I was unable to get the screen started out of the bezel. the Iopener did not seem to get hot enough. After a couple of cycles in the microwave the Iopener burst open. Rather than give up, I tried a small electronics heat gun on the right top corner. The heat gun did the trick and I was able to slowly work the glass off the bezel. Once the glass was off the job was straight forward just as the instructional video showed. I completed the job in less than two hours.
My Advice
The instructions for the Iopener should indicate heat times for 700 W or for larger full size microwaves. The instructions on the opener indicate not to reheat before at least two minutes had expired. I reheated after 5 mins and it burst.
iPad 3/4 Battery Image
iPad 3/4 Battery
$49.99
0 Comments
