My Problem
Cracked LCD Panel
My Fix
AWESOME! Great guide, but wound up not even needing it!
My Advice
On this model, replacing the LCD (ONLY the LCD, not the internal cable) is ridiculously easy. The front bezel (facing you while the laptop is open) can be carefully pry'ed loose and access to the screws is right there, one at each corner.
A heat gun would help a bit, as there is adhesive, but it can be done without.
The LCD alone can be replaced this way, without any other dissasembly. Once the display is loosened from its mounts, there is enough slack in the cable to let you fold the LCD down on to the keyboard and disconnect it.
0 Comments
