My Problem
Battery wouldn't keep a charge.
My Fix
Found out I can not see as well as I used to be able to.
My Advice
Be careful of the little brass clip that needs to be removed after removing the two screws holding the battery plug. I had it go twang and had to guess about how to put it back in. If you look closely one corner is rounded to give you a hint how it should go back in.
0 Comments
