My Problem
The battery began draining within a couple of hours, I tried many different things, such as shutting all apps off and factory reset and several other suggestions that were made, we tried them. But the result was the same, So, we finally decided to replace the battery thinking the battery was bad
My Fix
The repair went okay instructions were very helpful. The adhesive strips are a pain in the butt, due to they snapped off on me and it took forever to get the existing battery out since they were stuck to the bottom. But when I finally did, all went well. However, after replacing the battery, the home button no longer worked no matter what I did and unfortunately the problem still persisted with draining the battery. So it was quite a disappointment to find out that it probably wasn't the battery after all, there is something more serious wrong with it.
My Advice
Follow the video and you should have no problems replacing your battery.
0 Comments
