My Problem
Broken USB port on the motherboard needed replacing. I discovered that it was cheaper and easier to replace the entire motherboard as no micro soldering is involved.
My Fix
I placed the phone on a brightly colored towel (to keep screws from rolling, and protect both the phone and work surface). After reading the revised instructions (non-verified) several times, I took the phone apart step by step, being careful not to rip anything apart. All went exactly as described, and following the steps in reverse, resulted in a perfect fix. The hardest part was seeing the connection for the wi-fi cable. Reading glasses and a magnifier helped immensely. The phone now charges through the USB port, and the phone is back up to speed! I am very pleased with the results. I have a new phone for $70! Thank you IFixit.
My Advice
Read, and understand the instructions prior to ripping the phone apart. Wear your glasses, and use a magnifier if necessary to see what is where.
0 Comments
