« Back to All Stories
iMac HD Replacement Success!
mljackson -
iMac G5 20" Model A1076
iMac G5 20" Model A1076 Hard Drive Replacement
5 - 15 minutes
Moderate
My Problem
Factory HD went bad a few years after purchase
My Fix
The repair guide really helped, although it was not entirely accurate. The innards of my iMac didn't match the photos provided but I still managed to successfully perform the swap using the kit purchased from iFixit. Has worked perfectly ever since.
My Advice
Definitely get a sectional tray for storing and organizing the multitude of tiny screws you'll have to remove. Also make sure to carefully and completely clean the back side of the clear plastic display cover. Luckily, it's easy to remove and re-clean with the suction cups since it's attached magnetically. It goes without saying but BACK UP EVERYTHING ALWAYS!
1 TB 7200 RPM 3.5" Hard Drive Image
$69.99
Heavy-Duty Spudger Image
Heavy-Duty Spudger
Heavy-Duty Suction Cups (Pair) Image
$14.95
0 Comments
