My Problem
Battery would only last 6 hours if I fully charged it and didn't even use it sometimes in the day.
My Fix
Repair went super easy!! Just that to open it at first you do have to use a little bit more force than you think you would.
My Advice
I would recommend to do a battery timer reset like I did. If you don't do it phone might think you still have the old battery and you won't tell a whole lot difference from the old one to the new one. You simply drain the battery to zero, let it rest over night(or 4-5 hours) then charge it to a 100% and keep charging it 2 more hours, then unplug it and do a hard restart(simply hold the home button a power button for 6 to 10 seconds then let go of the home button, and let go of the power button when you see the apple logo). And your done!! You will tell a much better difference if you do this!
0 Comments
