« Back to All Stories
Not too bad
nmichels13 -
MacBook Pro 15" Unibody Late 2008 and Early 2009
MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement
Very difficult
My Problem
My lcd was bad
My Fix
As many others have said, getting the glass off was real tough, I found that when I wasn't having success in one corner, I tried a lower corner and it worked much better. From there I just pried all the way around, making sure to heat a bit as I went.
My Advice
I bought my led from Ifixit and there was a film over the screen! It had no obvious tabs, the way I knew it was there is there was like a pixelated "L" in the lower left portion of the screen! Very carefully use something (my nails were too short) to start pulling up the film, then pull it off. But only once you're ready to seal up the glass for good since you don't want any dust or smudges in there. Good luck
Spudger Image
Spudger
$3.99
P2 Pentalobe Screwdriver iPhone Image
$5.99
MacBook Pro 15" Unibody (Late 2008 - Late 2011) LCD Panel Image
$84.99
0 Comments
