« Back to All Stories
SuperDrive Replacement on MacBook Pro Model A1260
edmunds -
MacBook Core Duo
MacBook Core Duo Optical Drive Replacement
Moderate
My Problem
The SuperDrive would not accept a disk.
My Fix
The repair went very smoothly.
My Advice
Step 10 of the repair guide suggests you remove the ribbon cable attaching the SuperDrive connector to the logic board. I found this to be unnecessary. After removing the three screws holding the drive in place, I was able to lift the drive gently and slide it off the connector. Slipping the new one on the connector was just as easy. I try to avoid separating ribbon cables if I can avoid it.
MacBook/MacBook Pro 15" 8x SuperDrive Image
$69.99
0 Comments
