My Problem
Worn out battery that was failing to keep a good charge - under normal usage, battery would last less than 4 hours.
My Fix
Quick and smooth! The use of the plastic spudger to remove the battery along with the directions provided on ifixit's website made changing the battery to a newer slightly larger 2100mAh battery a breeze.
My Advice
Make sure if you are getting a replacement battery for the Droid 4 that it comes with the Torx screw driver or be prepared to have one available (I believe one can be purchased from ifixit as well). Luckily the battery provider provided one for me in this case, however, some do not. The minimum tools needed to do a battery change on the Droid 4 should be: Plastic Spudger and Torx Screwdriver
0 Comments
