iScrews iPhone Screw Trays
  • iScrews iPhone Screw Trays / iPhone 3G/3GS
  • iScrews iPhone Screw Trays / iPhone 4S
  • iScrews iPhone Screw Trays / iPhone 5c
$0.99
$0.99
We'll send a message when the product is back in stock.
Product Details
Features
Features
iScrews is a cardboard tray with individual compartments for every screw in your iPhone model.
These are great for techs to use over and over or just one repair.
Product Video
Repair Stories
User avatar
dgood's Story Photo #502294
My Problem
After having fixed the battery and speaker issue, ( https://www.ifixit.com/Story/12618/iphon... ), I had noticed that even when plugged in, every now and then, the iphone 4S would just suddenly start discharging, as if it were not plugged in. Also, when I replaced the speaker in my . . .
User avatar
My Problem
I'd dropped my iPhone 4 and smashed the rear glass panel. Genius Bar replacement cost in Australia appeared to be north of AUD$200 !
I took the opportunity to order other useful tools and accessories from the iFixit web site which all came in at less than half the cost of glass panel repair in Austr . . .
User avatar
My Problem
My iPhone 5 power button only worked sometimes. For a few dollars I replaced the power cable and battery and should be good for another 2 years. The new iPhone 6 is just not in the budget right now.
My Fix
The guides were great. Couldn't do the job without them. The pictures could be a little clearer w . . .
User avatar
My Problem
My niece dropped and shattered her IPhone 5s screen. After looking at the iFixit iPhone 5s Display Assembly Replacement, I thought I would try replacing the screen myself.
My Fix
I placed tape over the broken screen, before attaching the suction cup. The screen was weak from the cracks, so I used a sha . . .
User avatar
My Problem
Total blackout. After a popular "waterproof" case failed while snorkeling on vacation, threw my phone in a bag of rice and took it to a repair guy, the phone worked again after an ultrasonic isopropyl bath. But, it was never the same, it suffered a slow and painful death within the next 6 months poo . . .
User avatar
My Problem
Vertical lines on the screen on my 4s.
My Fix
Replaced the screen assembly, I needed to turn all but two screws in my phone. Mostly smooth, I pulled a little too hard on the upper mic cable (part of the headphone jack assembly) without enough prying and tore the cable. After he parts come in for that I need . . .
User avatar
My Problem
My iPhone was getting to 20% battery or less, and then dying like the battery was dead. Plug it in, and it would come to life at the smae battery % as when it shut off. Apple tested it, and the battery looked real good. We did a complete re-flash and hard reset, but the problem persisted. Checked it . . .
User avatar
My Problem
I had pushed so hard on the screen for about 2 years it became darkened with blotches and dark streaks. I could no longer read or see the screen info below the Blotches. I tried to heat remove and loosen up the glass from the display only after I had charged it for 48 hours straight with the screen . . .
User avatar
My Problem
After replacing the display and screen, I found that the home button was broken. ordered it and it came in a few days.
My Fix
Dismantling the entire iPhone was easier - since I already did it twice. This time I followed the directions, and as easy as pie!! Replaced the button, completed the project in a sh . . .
User avatar
My Problem
Phone would die after a couple of hours after being off the charger.
My Fix
Repair went ok, I got it back together but had white lines across the screen. After reading the FAQ found that the screen cables sometimes do not get all the way locked down and have to be put together. Took it back apart after the . . .
Show more
